Turn Software
Turn Software
Postby nyracerxxx » Wed Jul 24, 2024 11:05 pm
Sorry I did a search, can't seem to find the answer.
I have a license for UCCNC to run my Grizzly G0704, I've been using it as a mill but I have a need for Mill Turning.
Where do I find the Turn Software from UCCNC?
Another question is: Is there and easy way to configure the axis to comply with a lathe setup? or is it just easier to swap the plugs?
CR
nyracerxxx
Re: Turn Software
Postby cncdrive » Thu Jul 25, 2024 9:27 pm
UCCNC turn is only available in the latest development release 1.2116, you can download it from here: viewtopic.php?f=2&t=240&start=50
I don't understand your other question, please explain.
Re: Turn Software
Postby nyracerxxx » Sun Jul 28, 2024 10:15 pm
I have a mill setup with uccnc software so the z would be used instead of the X axis and X axis would be used instead on the Y axis.
nyracerxxx
Re: Turn Software
Postby cncdrive » Mon Jul 29, 2024 7:44 pm
You could make 2 separate profile files for the 2 different setup.
