Cool..Happy all worked out. Can have your tool change macro check field.
Sending 1 read function string can read many registers so let me know if you would like me to modify, it wouldn't take much to do.
Battwell wrote:these settings work with ecogoo9100 to set frequency only
i still cant work out how to get it to run- as nothing in the manual! ive spent way too long on it!
frequency source parameter p0.01 must be left at use keypad (0) not communication settings (7)
Battwell wrote:Addressing it as slave 1 , read registers (03) register 1 , 1 register
Battwell wrote:hi dan- that line failed too.
in the older hy plugin- what was different in the way they read/write compared to standard modbus?
just wondering if they are doing it the same in the newer model- but using different parameter numbers.
was it something like sending hi byte /low byte in wrong order ?
