AXBB-E
AXBB-E
Postby naijin » Thu Jun 12, 2025 5:35 am
Hi there, a few weeks ago my computer crashed, replaced it with a new one, downloaded and installed UCCNC, the latest version, but It will not run my cnc router
I use AXBB-E controller, when I start up UCCNC the little leds on the AXBB-E light up ( two green and purple/blue) but I ca not move any axis , the steppers lock up but no movement, I try to load a profile and it come up with the following text message and closes down:
The software was started with the /s CD08A1 command line argument, but a device with
This serial number was not found
The application will close now.
OK
Is there anything wrong with the controller? I tried to install and un-install the soft ware about six or so times and the result is the same, feels like there is no profile or it will not read any profiles, do I need to input all the pins and inputs again?
I have tried creating a new profile but the result is the same, any information will be greatly appreciated,
Cheers Nick
naijin
Re: AXBB-E
Postby mickecarlsson » Thu Jun 12, 2025 6:12 am
You need the license file with the serial number for the AXBB-E. Do you have it in a mail from where you bought the controller?
mickecarlsson
Re: AXBB-E
Postby cncdrive » Thu Jun 12, 2025 3:44 pm
Setup the IP address of the network card of your computer.
Please follow the AXBB-E users manual, it describes how to do it clearly.
Re: AXBB-E
Postby naijin » Sat Jun 14, 2025 6:01 am
Thank you all for the replies, problem solved ( must be old age catching up) I just done an axis set up by filling in the step and direction pins and ports with the correct information and it worked, isn't that a miracle or what??? :oops:
Cheers
Nick
naijin
Users browsing this forum: Google [Bot] and 7 guests
