Incomplete Ramp In
Incomplete Ramp In
Postby b57378 » Sat Apr 26, 2025 3:28 pm
Hi all, Recently switched to 1.2115.
I am having an issue with ramp in on profile cuts programmed from Vectric Aspire.
The last pass leaves an incomplete section when using a ramp in distance(5mm).
In other words, the profile is left with the ramp on the last pass depth instead of cutting the complete profile.
I switched back to 1.2113, loaded the same file and the profile cut out as it normally does.
It seems 1.2115 is interpreting the ramp differently?
Thanks in advance!
b57378
Re: Incomplete Ramp In
Postby cncdrive » Sun Apr 27, 2025 1:13 pm
I don't know what do you mean by "ramp"?
Postby b57378 » Sun Apr 27, 2025 4:01 pm
Giving the tool a 5mm ramp in distance(or angle) instead of Z plunging straight down when doing the next pass on a profile cut.
As mentioned I did test the same g-code file on both versions and they produce a different result, I will try and attach a picture of the part when I get a chance
b57378
Postby cncdrive » Mon Apr 28, 2025 12:41 am
Maybe your settings are different?
Postby b57378 » Mon Apr 28, 2025 6:46 am
I used the same file that was already toolpathed, Both versions of Uccnc profiles were setup from a fresh install.
I'm not sure if there could be a setting in Uccnc that would change the Z axis plunge behavior.
This is not a major issue for me, I just like to help improve if there are any bugs in the new version, I will try send a picture in next week.
Thanks.
b57378
Postby cncdrive » Mon Apr 28, 2025 11:00 am
It would be great if you could describe what exactly the problem is, what g-codes causing issues and what issues?
Postby b57378 » Wed Apr 30, 2025 7:27 am
It is quite difficult to explain.
I will switch back to 1.2115 and see if I can reproduce it and attach a photo.
b57378
