ATC Macro projekt
ATC Macro projekt
Postby JeeyBee » Wed Feb 22, 2017 11:28 am
I´m retrofitting a Brother TC211 for UCCNC and now its time for the toolchange macro.
First of all, where do I find documentation about the macro programming and reference syntax?
JeeyBee
Re: ATC Macro projekt
Postby JeeyBee » Wed Feb 22, 2017 11:55 am
Aah I looked there but I only registered the PDF files :D
I attached two pictures but they did not seem to show?
Ugh C#, why cant everybody stick with VB :)
JeeyBee
Postby JeeyBee » Wed Feb 22, 2017 12:27 pm
Is it possible to debug the code?
JeeyBee
Postby Battwell » Wed Feb 22, 2017 1:24 pm
if you look in your profile macro folder (in main uccnc directory) you will see macro errors.
make a shortcut to this file- on desktop etc.
it gives a good indication of errors.
note uccnc macros can be finiky about capitals etc-
it updates after every macro error at runtime
Postby JeeyBee » Wed Feb 22, 2017 1:44 pm
More questions
Whats the string to get a digital input?
Like setoutput port pin but instead get input port pin.
Got it "GetLED"
JeeyBee
Postby JeeyBee » Thu Feb 23, 2017 7:51 pm
Done!
The toolchanger is controlled with an arduino.
https://youtu.be/10IQWyFWIfs
JeeyBee
Postby cncdrive » Thu Feb 23, 2017 10:01 pm
Wow, nice job, you finished with this pretty fast. :)
Are you using the UCCNC modbus plugin to send data to the Arduino which then controls the ATC?
Postby JeeyBee » Fri Feb 24, 2017 10:46 am
I thought it would be a good thing to take one thing at a time so I made it simple so that UCCCNC i sending a combination of four signals that is the same as the toolchanger gives the arduino.
The little bit tricky thing was that I cant wait for the right signals on the toolchanger because then its too late to stop it and it will move on past the right position so I had to count the positions and then verify it with the sensors.
Attached is the macro if anyone is interrested.
M6.txt
(4.83 KiB) Downloaded 1206 times
JeeyBee
Postby lp_felix » Sun Apr 17, 2022 9:01 am
Hi
How can you prevent the user to move Z up until reach atc zone?
lp_felix
