Writing variable to a location outside of the macro possibl?
Postby eMTea » Tue Aug 16, 2022 8:31 pm
Hi!
Is it possible to execute a macro, who (in between other stuff) can store a variable (in this case, a tool number) in a location ouside of the macro?
And then another separate macro can access that variable and reload the previous tool?
eMTea
Re: Writing variable to a location outside of the macro poss
Postby ger21 » Tue Aug 16, 2022 10:52 pm
Yes, you can either store it in a field on the screen, or in a VAR.
Postby eMTea » Wed Aug 17, 2022 9:32 am
Ok! Thanks for confirming!
eMTea
Postby eMTea » Wed Aug 17, 2022 5:19 pm
Is there a certain list of VAR's that is not used, or is recommended to use, to not mess up already used VAR's?
eMTea
Postby Battwell » Fri Aug 19, 2022 8:51 am
depends if your using other peoples macros? for example mine are all in the 2800 range.
plenty to choose from
Postby ger21 » Fri Aug 19, 2022 10:45 am
I believe that only the probing VARS should not be used.
