yes +1!
Raising the Z when feed hold activates is something like, also beeing able to jog while feed hold is active as i can with my current multicam machine. Allows me to remove whatever moved or came loose before resuming.
Battwell wrote:feedhold as it is works well on a router, leaves spindle running (unlike stop)
great when a cut part spits out from the job and just needs to be moved before continuing.
i prefered how it worked in mach 3 where in feedhold you could say adjust a dro a bit then continue, but uccnc isnt mach3 and ive learnt its work arounds.
obviously, mill and plasma needs differ in what we think feedhold should do.
Battwell wrote:nothing special dan. feedhold is feedhold only.
if a dro needs a tweek etc stop must be pressed, tweek the dro , restart spindle, press cycle start
** **remember to restart spindle **** !!!!
