charliem wrote:Looking at the manual you have everything wired correctly. and you say that the probe has a led that goes from one color to another when activated. so the probe is working. Do you have a volt meter that you can measure the signal side and make sure the signal is going to 0 volts when activated? The other possibility is something is software is not set correctly. HAng in there youll get this figured out.
