Dan911 wrote:Most importantly what region was the UCR201 plugin set to?
PillyWilly wrote:Dan911 wrote:Most importantly what region was the UCR201 plugin set to?
Europe
As we all know Europe uses a comma for decimal separator and Gerry"s macros handle this to use a period and precision decimal places.
The solution is to always convert the number to a fixed amount of decimal numbers or to check the string for the e character and if it has it then convert the number.
It has to be done in the macros, because Windows may output exponent format, it happens with very small and very large numbers when there would be lots of 0s otherwise, like 0.00000012.
So, this might be the root of the problem, but ofcourse this is just an idea from me for now, because we did not see the issue yet, so it is just a guess.
One thing which can be a problem though is with math calculations when the calculated number comes out in exponent format, e.g. 1.2e-6.
