Synchronous with motion macros for stand alone THC.
Re: Synchronous with motion macros for stand alone THC.
Postby ErikMc » Fri Jun 21, 2019 11:13 am
Ok great thanks a lot for clearing that up!! Yes I have the 1.2049 and got it to work with the m10/m11. I will try out the developement ver. I am intrested in the m10.1/m11.1 as my sheetcam puts my thc off in front of the m03. I noticed the thc freeze did not come on during thos instances. In the new version will the m10.1 be on the same configure page? Thanks a lot for your help!! Just a newb with newb probloms hahaha
ErikMc
Postby shad » Fri Jun 21, 2019 6:50 pm
Please Look on this as on the example of the cutting program.
M10.1/M11.1 used for Plasma Start
M10.2/M11.2 used for Automatic disable/Corner
And use this macro from Dezsoe for disable Plasma start output pin on program stop.
viewtopic.php?f=16&t=1101&start=20#p10995
(Filename:c:\5cm-test.dxf)
(Date:06.15.19 7:04:51 +03:00)
(CutWidth:0,7mm)
G21(Units: Metric)
G53 G90 G91.1 G40
N00001G00 X34.15 Y21.21
N00002(Perimeter start)
N00003M03
N00004M10.1 (Plasma Cutter Start)
N00005G01 X33.34 Y20.40 F8250
N00006G03 X35.30 Y21.21 I0.81 J0.81
N00007G03 X33.00 Y21.21 I-1.15 J0.00
N00008G03 X33.34 Y20.40 I1.15 J0.00
N00009M11.1 (Plasma Cutter STOP)
N00010M05
N00011G00 X17.42 Y35.58
N00012(Perimeter start)
N00013M03
N00014M10.1 (Plasma Cutter Start)
N00015G01 X24.25 Y42.40 F8250
N00016G03 X7.77 Y35.58 I-6.82 J-6.82
N00017G03 X27.07 Y35.58 I9.65 J0.00
N00018G03 X24.25 Y42.40 I-9.65 J0.00
N00019M11.1 (Plasma Cutter STOP)
N00020M05
N00021G00 X15.54 Y13.45
N00022(Perimeter start)
N00023M03
N00024M10.1 (Plasma Cutter Start)
N00025G01 X14.02 Y11.92 F8250
N00026G03 X17.69 Y13.45 I1.52 J1.52
N00027G03 X13.39 Y13.45 I-2.15 J0.00
N00028G03 X14.02 Y11.92 I2.15 J0.00
N00029M11.1 (Plasma Cutter STOP)
N00030M05
N00031G00 X39.10 Y35.69
N00032(Perimeter start)
N00033M03
N00034M10.1 (Plasma Cutter Start)
N00035G01 X42.39 Y38.98 F8250
N00036G03 X34.45 Y35.69 I-3.29 J-3.29
N00037G03 X43.75 Y35.69 I4.65 J0.00
N00038G03 X42.39 Y38.98 I-4.65 J0.00
N00039M11.1 (Plasma Cutter STOP)
N00040M05
N00041G00 X50.35 Y53.35
N00042(Perimeter start)
N00043M03
N00044M10.1 (Plasma Cutter Start)
N00045G01 X50.35 Y50.35 F8250
N00046G01 X50.35 Y41.79
N00047M10.2 (AVC ON)
N00048G01 X50.35 Y10.57
N00049M11.2 (AVCOFF)
N00050G01 X50.35 Y0.00
N00051G02 X50.00 Y-0.35 I-0.35 J0.00
N00052G01 X39.00 Y-0.35
N00053M10.2 (AVC ON)
N00054G01 X11.00 Y-0.35
N00055M11.2 (AVCOFF)
N00056G01 X0.00 Y-0.35
N00057G02 X-0.35 Y0.00 I0.00 J0.35
N00058G01 X-0.35 Y11.00
N00059M10.2 (AVC ON)
N00060G01 X-0.35 Y39.00
N00061M11.2 (AVCOFF)
N00062G01 X-0.35 Y50.00
N00063G02 X0.00 Y50.35 I0.35 J0.00
N00064G01 X10.57 Y50.35
N00065M10.2 (AVC ON)
N00066G01 X40.78 Y50.35
N00067M11.2 (AVCOFF)
N00068G01 X50.35 Y50.35
N00069G01 X52.36 Y50.35
N00070M11.1 (Plasma Cutter STOP)
N00071M05
N00072M30
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
http://neuroncnc.com/
shad
Postby beefy » Fri Jun 21, 2019 9:51 pm
ErikMc wrote: my sheetcam puts my thc off in front of the m03.
Erik,
could you tell me what post processor you are using in Sheetcam.
Click on Options / Machine then a "Machine options" box will pop up.
Click on the Post processor tab and the following will be displayed:
Keith.
beefy
Postby ErikMc » Sat Jun 22, 2019 11:17 am
It’s a post processor that Les made for me. I downloaded the development uccnc and the m10.1 to freeze the thc works great!!! Thanks for the help.
ErikMc
Postby beefy » Sat Jun 22, 2019 1:22 pm
Erik,
would you be kind enough to upload a copy of your post processor here.
My post processor does NOT put path rule code snippets before M3. There are at least myself and one other guy that would like to have our code snippets put before M3, and it seems like your post processor does that.
Keith.
beefy
Return to CNC Plasma
