Abnormal behaviour probe
Postby antonfat » Sat Apr 13, 2024 3:11 am
Greetings. I have a problem with the probe procedure. I use windows 10 and ABBX-E. Let me explain, I choose the type of probing for example zero piece or the center of a hole etc. At the first procedure everything is fine, but if I want to repeat another survey even different from the previous one, the milling machine behaves with axis movements that make no sense.
antonfat
Re: Abnormal behaviour probe
Postby antonfat » Sat Apr 13, 2024 4:45 am
fix: I use Windows 10 and AXBB-E
antonfat
