It is normal that this code smashes into touch probe with rapid feed?
G1 G94
G31 A90 F90
A axis is rotary (deg/min)
Doncis wrote:Thanks, I will check later.
I assume that it exclude feed rate only for display purposes. Imagine you want to cut simple slot only with A axis, with set G1 deg/min feed rate, and boom crash with rapid feed..it should always respect G1..
btw I always use G93 for 4axis.
G1 Fx
G94 G1 Fx
