tool change macro
tool change macro
Postby wassupcrew » Wed Mar 10, 2021 9:42 pm
having recently changed from mach3, i am trying to get a working semi auto toolchange macro. in mach3, i set zero on the part and then pressed my toolchange button and the machine would go to my fixed probe position, probe twice and then return to the part zero. upon a tool change the machine would go to my toolchange position and wait for me to change tools then i would press the toolchange button and it would probe the new tool and update the zposition. i would like to have something similar in uccnc. the current m31 i am using does exactly what i want apart from it doesn't update the tool offset box in the offset screen. can anybody help with this please. attached are my script from mach3 and my m31 from uccnc. Thanks all
M31.txt
(2.14 KiB) Downloaded 531 times
M6 End.txt
(473 Bytes) Downloaded 510 times
M6 Start.txt
(167 Bytes) Downloaded 514 times
toolchange.txt
(2.35 KiB) Downloaded 511 times
wassupcrew
Re: tool change macro
Postby SpeedyE46 » Sat Apr 10, 2021 3:16 pm
Hi there.
I am in the exact same situation. In Mach3 I zero Z with a touch probe (Tool 0), then move to a fixed length sensor to set Z offset, then change to tool 1 and use the lenght sensor to update Z offset for the new tool.
That was very well working and I wish I could have this workflow in UCCNC.
Is there any plugin that would do that?
Cheers
Speedy
SpeedyE46
