Jog multiple axiis
Re: Jog multiple axiis
Postby Zed_UCCNC » Tue Mar 09, 2021 2:31 pm
dezsoe wrote:Yes. I can confirm that with UC100 and with your profile I can reproduce the problem. First I need to change to step jog mode, then jog all axes at least once. After this if I jog any axis then the other two will also move.
Thank you.
Please also note I have the same problem with AXBB-E
Zed_UCCNC
Postby Zed_UCCNC » Wed Mar 31, 2021 1:19 pm
dezsoe: Do you have any information on this issue, how it will fit into the schedule or cycle of software development?
Zed_UCCNC
Postby dezsoe » Wed Mar 31, 2021 1:33 pm
No, but hopefully cncdrive will answer you.
Postby cncdrive » Thu Apr 01, 2021 11:37 am
My API developer collegue is currently checking the issue and hopfully can fix it soon.
Postby Zed_UCCNC » Thu Apr 01, 2021 12:41 pm
cncdrive wrote:My API developer collegue is currently checking the issue and hopfully can fix it soon.
I am glad to hear this!
I will keep looking for news.
Zed_UCCNC
Postby Zed_UCCNC » Sat Apr 17, 2021 12:18 pm
Is there any progress on this issue?
Would this be addressed in the next release or as an interim patch?
Zed_UCCNC
Postby cncdrive » Fri Apr 30, 2021 2:49 am
What we see is that the issue is caused by the backlash compensation which you have enabled in your profile.
My collegue is working on it, but it does not seems to be an easy to fix problem, so it will probably take some time.
Postby Zed_UCCNC » Fri Apr 30, 2021 12:06 pm
cncdrive wrote:What we see is that the issue is caused by the backlash compensation which you have enabled in your profile.
What is your plan for the problem?
Do you plan on fixing it in the next release?
As you know backlash compensation is basic to CNC machining, including jogging to an edge for location.
Zed_UCCNC
Postby cncdrive » Fri Apr 30, 2021 4:05 pm
I don't think we can fix it to the next release, but hopefully for the next next release.
And this was a known problem we just forgot about it, because basically it causes no error, because those movements are inside the backlash area.
But my collegue will try to fix it to make it not to happen.
