Hello. I had to change from an old computer with parallel port to use my laptop (Win 10) for my CNC with Mach3 software so I purchased the cncdrive.com UC100 CNC Motion Controller. Version of Mach 3 Controller R2.63
It all seemed to install OK. Blue and green lights on the back ok. In USB devices in windows ok. Setup pin/port Input signals for estop and motor outputs ok. Screen shots in attachment.
But the message "Emergency mode active…. Press reset…." continues to come up and the RESET button flashes red.
I tried different ways of installing. New install. Using old files from original install. Always the same result.
One issue I get but only when I exit the Mach3 program. I don't know if it's related.
XMLNetProfile - Load Warning – (small square character) hexadecimal value 0x18, is an invalid character. Line 1, position 415.
Thank you if you can assist.
Sue.
