Block and Unblock Gcode lines
Postby Dan911 » Mon Dec 17, 2018 11:51 am
I read about this feature in link below and looked useful to have on hand, it will be added to UCCNC in the very near future but in the mean time can you try it here.
viewtopic.php?f=2&t=1682
By adding a forward slash to the beginning of a gcode line this gives you the option to block line if needed with macro #4545, and unblock it with
macro#4646. If you want to add a button to use macro's you will have to change the macro numbering, I suggest the multiple macro plugin that could be found in toolbox forum section.
M4545.txt
(572 Bytes) Downloaded 1614 times
M4646.txt
(616 Bytes) Downloaded 1629 times
Re: Block and Unblock Gcode lines
Postby beefy » Mon Dec 17, 2018 12:19 pm
Cheers Dan.
Keith.
beefy
Postby Robertspark » Mon Dec 17, 2018 11:27 pm
Nice Dan, thanks
Postby dammogreen » Fri Feb 15, 2019 2:07 am
Whoot! I'll try it out. What a great idea ;-) ;-) Thanks for the implementation someday I'll give back with a plugin.
dammogreen
Return to UCCNC TOOL BOX
