work will continue after the summer holidays. there will be a gerber import option to generate the autoleveled gcode directly to uccnc. that's the plan.
dhanger wrote:I've been trying out the autoleveler for the first time, got most of it figured out but stuck on one snag.
UCCNC v1.2111
Autoleveler 1.0048
UC100 Demo mode
Under 'digitize file' I've been able to use 'none' (generating both leveling and G code file in one), and 'create' (created a leveling file), but can't get 'use' to work. I'm assuming 'use' is for applying a leveling file created with 'create' and then afterwards applying to the G code file I want to run. Using 'create' runs the probe point routine in UCCNC based on the G code file and then prompts to save the leveling file, I save it in the same location as the G code file I want to run, with no extension on the file name. When I try to run 'use' I try to open the leveling file I just created (using the ellipsis, not 'File Open') but all I get is 'wrong file' and can't go any further. I've tried renaming the leveling file with various extensions (.txt, etc.) but nothing works. What do I need to do to open the leveling file?
Users browsing this forum: Bing [Bot] and 4 guests
