WHB04B-4 Pendant Plugin
Re: WHB04B-4 Pendant Plugin
Postby shad » Mon May 25, 2020 2:09 pm
Please check this one.
But you have to know that pendant send report about current state to the plugin only on pendant power on or when button pressed or other events.
If you start UCCNC and pendant was on - current state of the pendant will not send to UCCNC. You have to press any button or set speed for update.
WHB04B-4 Pendant.rar
(179.48 KiB) Downloaded 1030 times
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
http://neuroncnc.com/
shad
Postby Gunnar » Wed May 27, 2020 4:48 pm
Hi Shad,
the 6 axis pendant ist recognized by UCCNC without any problem and works as designed but only for 4 axis. When I switch to axis B or C the values of A are changed. So it is currently not a pendant for X+Y+Z+A+B+C to be chosen by the rotary switch but for X+Y+Z+A+A+A.
Do you think this can somehow be changed? Can I help or support you with this? Debugging or logging the communication between pendant and UCCNC?
Thanks for your great work!
Gunnar
Gunnar
Postby shad » Sat May 30, 2020 8:45 pm
I have not pendant for 6 axis - can you make a short video of the pendant display when you select B and C axis?
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
shad
Postby Gunnar » Mon Jun 01, 2020 7:37 pm
Ok, I'll make a video tomorrow. Is it ok if I send it to your neuroncnc-Email address?
Gunnar
Postby shad » Tue Jun 02, 2020 6:24 am
It's will be great!
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
shad
Postby Gunnar » Wed Jun 03, 2020 7:27 am
Hi Shad,
I sent out the video yesterday. Hope it didn't get lost along the way...
Cheers, Gunnar
Gunnar
Postby shad » Wed Jun 03, 2020 10:35 am
Got it! Thank you.
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
shad
Postby shad » Mon Jun 08, 2020 8:04 am
Try this one for testing.
WHB04B-4 Pendant_6Axistest.rar
(181.26 KiB) Downloaded 923 times
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
shad
Postby Gunnar » Fri Jun 12, 2020 7:00 am
Thanks! Will test this weekend and post feedback!
Gunnar
Postby Gunnar » Thu Jun 18, 2020 12:14 pm
Hi Shad,
sorry for the late feedback, it's been a busy week.
Your test version works like a charm. I didn't have a chance to test everything in detail, but the movement of B and C axis are now working like the A axis did in the former version :-) So if you did not include any new bugs we have a working plugin for the 6-axis-plugin now! :-D
Thank you very much!!
Cheers,
Gunnar
Gunnar
