run from here problem
PostPosted: Mon May 24, 2021 1:19 pm
by courtjester
Hi
I am running Neon 2113 screenset and when I have to use the "run from here" function the menu that appears on the screen has the bottom chopped off. There are 2 options to select from and I cannot see them, it seems the menu box is not tall enough. I'm not sure if this is a Macro problem or not but it seems the display size needs to be taller so I can see what the box labels are. :o
Re: run from here problem
PostPosted: Mon May 24, 2021 7:15 pm
by dezsoe
In Windows at the display settings set the text size to 100%.
