AXBB-E ethernet connection
Postby ricky_h » Tue Jun 18, 2019 1:03 am
Hi, I'm not having much luck at connecting to the network! I've followed all the instructions for the AXBB-E i.e.
ip address 10.10.10.10
subnet mask 255.255.255.0
when I ping from the cmd prompt I get a valid return, but when I use the util tool, it doesn't detect the AXBB-E although the blue led light does flicker once on as I run the util
help please?
I haven't connected the 24v supply, just the 5v
also, I haven't received an email with the passkey from Cncdrive yet. could this be the problem?
I can't see why the hardware wouldn't work without Uccnc running?
thanks
ricky_h
Re: AXBB-E ethernet connection
Postby skrap » Tue Jun 18, 2019 2:55 am
Pinging 10.10.10.10 just shows that the ethernet adapter is setup correctly as the computer is just pinging itself.
Are you using either a crossover cable or switch/router?
skrap
Postby ricky_h » Tue Jun 18, 2019 3:54 am
Hi Skrap,
I've tried using a crossed cable direct from the pc to axbb,
I've also tried going via the router using normal cables
I've tried using a different pc (both pc's running windows 10 with net 3.5 enabled)
I've tried resetting the axbb
but not getting the blue light on, it just flashes once when I use the UCxxx utility
ricky_h
Postby cncdrive » Tue Jun 18, 2019 5:59 am
You need the latest UCCNC development release for the AXBB-E controller.
From the pictures you uploaded I can tell that you using an older version which will not work with the AXBB-E.
The direct download link: http://www.cncdrive.com/UCCNC/get_devUCCNC.php
And you pinging the network adapter (10.10.10.10.), the IP of the AXBB-E is 10.10.10.11. by default.
The blue LED flashes once when the AXBB-E receives the broadcast message from the PC which the Utility tool sends to explore the devices.
Postby ricky_h » Tue Jun 18, 2019 7:57 am
ah, well that explains it, thanks
I thought that I was going mad!
but this is the version that still is on the site today,
Do I still need a license key with the new axbb?
will that be emailed to me?
ricky_h
Postby cncdrive » Tue Jun 18, 2019 8:13 am
Roll down that webpage, the download link is there.
Yes, ofcourse you need a license key if you want to use the UCCNC with any of our motion controllers including the AXBB-E.
Postby ricky_h » Tue Jun 18, 2019 9:57 am
ok, will the license key be emailed to me?
I bought the AXBB & license only recently, there wasn't anything else in the box
ricky_h
Postby cncdrive » Tue Jun 18, 2019 10:25 am
License keys are emailed with our licensing software, usually on shipping date, sometimes with a little delay.
Postby ricky_h » Tue Jun 18, 2019 9:30 pm
thanks, email arrived today
ricky_h
Users browsing this forum: Google [Bot] and 2 guests
