Delay before piercing
Re: Delay before piercing
Postby Rad » Mon Feb 19, 2018 3:00 am
(G28.1)
N0100 G00 Z0.7500
N0110 X1.2448 Y2.9995
N0120 Z0.1500
N0130 G28.1 Z0.12
N0140 G92 Z0.0
N0150 G00 Z0.0800
N0160 G92 Z0.0
N0170 G00 Z0.1500
N0180 M03
Rad
Postby Rad » Mon Feb 19, 2018 3:14 am
Timed the delay to be around 3sec
Rad
Postby cncdrive » Mon Feb 19, 2018 3:33 am
OK, I ran your code with some random settings using a UC100 and the G28.1 in your code take around 0.5seconds at me.
The G28.1 is not a fast code though, it is to home the machine, so software has to syncronise a few times with the motion controller.
However the 3sec still sounds like a lot, much more than what I see.
Can you post your .pro profile file to let me test it also using your settings?
And the same time I advice you to use the G31 instead of the G28.1, that code is for probing and it works much faster.
Postby asuratman » Thu Feb 22, 2018 3:47 am
Do you guys use ohmic sensing to touch plate then go to piercing height ? Is it possible using ohmic sensing on oxy torch to touch steel plate then go to piercing height ?
asuratman
Return to CNC Plasma
