AXBB-E mach 3 setup
Dazp1976
Re: AXBB-E mach 3 setup
Post by Dazp1976 »
gills wrote:
configure plugin isn't on my main screen, plugin control is. When I click on it this is what appears:
That one at the bottom "analog output 1".
I actually don't know "value" meaning but check the "spindle" box and see if you get AO1 voltage when you enter a M3S speed.
If not it may need a "value" too.
Forgot, set up your pulley too.
Dazp1976
Post by Dazp1976 »
Managed to have a quick check of mine earlier.
Go to:
Plugin control > "Analog output 1"
Tick the Spindle box.
Set value as "V".... For voltage!!
That should do it!!!!!!.
I have loads of pics of my confic and a shaky vid showing it all working via midi commands if you want a look.
Dazp1976
Post by Dazp1976 »
gills wrote:
The attachment main screen.PNG is no longer available
PART 1>.........
So. I briefly set up my uc300eth for spindle/cool/analog controls. Wired directly to an optocoupler module and voltmeter and set up to mach3.
Plugin slightly different but similar to axbb-e. Both units are the 300eth chip controller.
My axis numbers and outputs will be different to yours but you know where you are with those.
1. connection.
connection.
connection.
2. My axis/spindle output numbers.
3. General Outputs. NOTE: They are set Active high. Active low setting switched my controls on by default.
General Outputs
General Outputs
4. Spindle settings for pwm/analog use. (3% min to restrict spin speed too low for spindle).
Spindle settings
Spindle settings
5. Pulley set for router type.
6. Open 'Plugin control'. (note is 300eth).
Plugin control.
Plugin control.
Continued in next post, Part 2>......
Dazp1976
Post by Dazp1976 »
Dazp1976 wrote: Continued in next post, Part 2>......
Part 2>........
7. Plugin voltage setting for analog voltage pwm use. Check spindle check box, set value as V for Voltage.
8. Test run. M3S18000 command.
9. Test run success. CW light on opto module, Good Voltage reading on Voltmeter coming from Analog port 1.
Test run success
Test run success
10. Input M5 to stop test.
11. Success. CW Light goes off and Analog voltage goes to 0v.
Success. Analog works
Hope this helps somehow.
Tested the other controls too and M4,M7,M8 all light up their connected optocouplers and I did a brief shaky vid of it.
Dazp1976
Post by Dazp1976 »
Part 2B>........
Got some screen grabs from the video of all working.
gills
Post by gills »
Dazp1976, you are da man. My 24v relay was bad, I had a few more and put another one in and its up and spinning. Thank you for your knowledge, it is very much appreciated.
Dazp1976
Post by Dazp1976 »
gills wrote: Dazp1976, you are da man. My 24v relay was bad, I had a few more and put another one in and its up and spinning. Thank you for your knowledge, it is very much appreciated.
Eureka!.
That's awesome to hear mate :)
Got there in the end, I never considered a dodgy relay. I thought it was more to do with getting the analog going.
Just the fine tuning left to go :D
I got a bunch of spare relays from Aliexpress while I wasn't in a hurry for them:
https://www.aliexpress.com/item/1005003 ... WwbN4&mp=1
(just 1 example).
I get almost all my elec bits from there these days, you can get anything!. I live in UK so spare parts are really limited and they're sometimes 4 times the price.
gills
Post by gills »
Eureka!.
(just 1 example).
Dazp1976, with the AXBBE can you jog multiple axis at the same time??
Post by cncdrive »
Yes, you can.
Post Reply
