Battwell wrote:id prefer it to always show- probably to 2 decimal places - as some registers will probably show this accuracy- like if output volts was monitored etc?
so instead of 5 it reads 5.00 5.2 would read 5.20
this would be more like reading a digital multi meter. - the decimal places always show
dezsoe wrote:Hi Dan,
It's easy: use number.ToString("F2") to have always 2 decimals.
alex_s wrote:Hi Dan,
Settings as of Powtran should be F0.02 = 1, F0.11 = 4, F9.00=6005 F9.05=31 ( 9600 Baud 8N2 in PPO5 format ).
I also sent them the constructed command as of the manual and asked for confirmation on the correct Structure.
cheers
Alex
EDIT:
SLAVE = 01
CODE = 06
ADDRESSH = 20
ADDRESSL = 00
HIGH DATA = 00
LOW DATA = 01
HIGH CRC = 43
LOW CRC = CA
as of powtran should cause spindle Start in FWD Mode
here is a pdf if it help the settings are different at the top but the once i posted are the correct ones
https://www.dropbox.com/s/7l5v5msvp8k06rt/485.pdf?dl=0
