// M20304 Seting the spindle speed, runing CW/CCW and reading some VFD and spindle parameters.
// This is a Modbus interface macro and is running in a macro loop.
// When this macro is called it will check the Set Spindle Speed and the Speindle Speed Override DRO
// and will calculate the matching frequency. This is set in Modbus register which is sent to the VFD.
// After this step it will check the state of RUN CW/CCW LEDs and will set the necessary VFD commands.
// Last it will read some VFD parameters and display in UCCNC.
// Constants
ushort RunSpindleCW = 129; // Rexroth EFC5610 RUN CW command
ushort RunSpindleCCW = 133; // Rexroth EFC5610 RUN CCW command
ushort StopSpindleRun = 136; // Rexroth EFC5610 STOP command
ushort SSetDRO = 869;
ushort SactDRO = 870;
ushort SSOverriddenDRO = 2451;
ushort MaxSpindleSpeedDRO = 178;
double MaximumRPM = 24000;
int OutputVoltage = 20010; // VFD and spindle monitoring parameter field numbers
int OutputCurrent = 20011;
int OutputPower = 20012;
int DCBusVoltage = 20013;
int OutputTorque = 20014;
int PowerModuleTemp = 20015;
int ActualSpeed = 20016;
int SpindleTemp = 20017;
int SpeedArrival = 800;
ushort OutputVoltageDRO = 20010;
ushort OutputCurrentDRO = 20011;
ushort OutputPowerDRO = 20012;
ushort DCBusVoltageDRO = 20013;
ushort OutputTorqueDRO = 20014;
ushort PowerModuleTempDRO = 20015;
ushort ActualSpeedDRO = 20016;
ushort SpindleTempDRO = 20017;
ushort SpeedArrivalLED = 800;
ushort SpindleRunReg = 0; // Dispayed UCCNC Modbus register list
ushort VFDFrequencyReg = 1;
ushort ActualSpeedReg = 11;
ushort OutputVoltageReg = 20;
ushort OutputCurrentReg = 10;
ushort OutputPowerReg = 22;
ushort DCBusVoltageReg = 23;
ushort OutputTorqueReg = 24;
ushort PowerModuleTempReg = 30;
ushort SpeedArrivalReg = 40;
// Variables
string SspeedOverride;
int IndexOfPercentSign;
string SSpeedOverride;
double Current;
double Power_kW;
double Torque;
double SSpeedHz;
// Program starts here
//-------------- Set spindle speed value firtst ---------------------------------------------------------------
MaximumRPM = AS3.Getfielddouble(MaxSpindleSpeedDRO);
SSpeedHz = ( AS3.Getfielddouble(SSOverriddenDRO));
if (SSpeedHz > MaximumRPM)
SSpeedHz = MaximumRPM; // Force maximum RPM to prevent exception
// Calculate the matching RPM frequency and send the value to Modbus register.
exec.SetModbusregister(VFDFrequencyReg, (ushort) Convert.ToUInt16(SSpeedHz / 0.6));
//-------------- Send start/stop command for the spindle --------------------------------------------------------
// Check the CW and CCW LEDs and convert the state to spindle control commands.
// The command is set in the Modbus register which is sent to VFD using the UCCNC Modbus internal handler.
// Check CW and CCW LEDs, start or stop the spindle based on LED states.
// After exiting this macro the Modbus register is set up for CW, CCW or Stop
if ( AS3.GetLED(50) == true ) // If the RUN CW LED is active
exec.SetModbusregister(SpindleRunReg, RunSpindleCW); //Turn spindle on in CW rotation if LED is on
else
if ( AS3.GetLED(51) == true ) // If the RUN CCW LED is active
exec.SetModbusregister(SpindleRunReg, RunSpindleCCW); //Turn spindle on in CCW rotation if LED is on
else // CW and CCW LEDs are off, send turn spindle OFF commnad
exec.SetModbusregister(SpindleRunReg, StopSpindleRun); // Send Rexroth EFC5610 STOP command to VFD
// Reading the VFD parameters via Modbus
// Get the parameters from the VFD and output to display
exec.GetModbusregister(OutputVoltageReg, out OutputVoltageDRO);
AS3.Setfield(OutputVoltageDRO, OutputVoltage);
exec.GetModbusregister(OutputCurrentReg, out OutputCurrentDRO);
Current = Convert.ToDouble(OutputCurrentDRO * 0.01);
AS3.Setfield(Current, OutputCurrent);
exec.GetModbusregister(OutputPowerReg, out OutputPowerDRO);
Power_kW = Convert.ToDouble(OutputPowerDRO * 0.1);
AS3.Setfield(Power_kW, OutputPower);
exec.GetModbusregister(DCBusVoltageReg, out DCBusVoltageDRO);
AS3.Setfield(DCBusVoltageDRO, DCBusVoltage);
exec.GetModbusregister(OutputTorqueReg, out OutputTorqueDRO);
Torque = Convert.ToDouble(OutputTorqueDRO) * 0.1;
AS3.Setfield(Torque, OutputTorque);
exec.GetModbusregister(PowerModuleTempReg, out PowerModuleTempDRO);
AS3.Setfield(PowerModuleTempDRO, PowerModuleTemp);
exec.GetModbusregister(ActualSpeedReg, out ActualSpeedDRO);
AS3.Setfield(ActualSpeedDRO, ActualSpeed);
AS3.Setfield(ActualSpeedDRO, SactDRO);
exec.GetModbusregister(PowerModuleTempReg, out SpindleTempDRO);
AS3.Setfield(SpindleTempDRO, SpindleTemp); // Temorarily set the power module temp here
exec.GetModbusregister(SpeedArrivalReg, out SpeedArrivalLED);
if (SpeedArrivalLED == 1)
AS3.SetLED(true, SpeedArrival);
else
AS3.SetLED(false, SpeedArrival);
if (AS3.Getbuttonstate(144) == true) //Check if the Reset button is active.
exec.Clroutpin(3, 17); // Turn off the fan
AS3.SetLED(false, 801); // Turn off the LED
// End of program
Users browsing this forum: Roby and 7 guests
