Ran across this. If you use steps on any increment and run up against your soft limit it will not move until you do a reset. This happens if you have show message on soft limit checked or unchecked. Even if you OK message box, with messages enabled. Another issue if you uncheck show message option and if your close to your soft limit, and do a 1" step it will go right past soft limit, and in my case hit my hard limit switch. This is 100% repeatable. This is on screen controls, no MPG attached or plugin enabled/
Thanks Joe
