The application lost the connection with the motion controller device.
The error began to occur with different frequency. Tried to connect to another computer. The result is the same. UCCNC control is the latest version.
Battwell wrote:which controller?
this is usually because of electrical noise from the vfd.
or power saving causing a shutdown of communication.
cncgefest wrote:UC300ETH. The controller is powered by a separate power supply through the decoupling board UCSB single port breakout board (https://www.cncdrive.com/UCSB.html). 24V enters the board, the board converter sends 5V to the motion controller
