Chess Pieces
Chess Pieces
Postby Greolt » Sun Mar 26, 2023 1:40 am
Some of my grandchildren are learning to play chess, so I thought I would make them a chess set.
All the pieces are made on the rotary axis. With UCCNC of course. The board not so much.
Jarrah and Australian Cyprus.
Greolt
Re: Chess Pieces
Postby ger21 » Sun Mar 26, 2023 11:48 pm
Very nice.
Re: Chess Pieces
Postby A_Camera » Tue Mar 28, 2023 1:07 pm
Wow. That's really very nice. Where did you find the G code? Or did you do the design everything on your own? The pieces look really beautiful. I have a Millennium King Performance chess computer which I like a lot and also considered making new pieces for, but I simply don't have the patience and the code... Maybe next year when I'll have a bit more time... ;)
A_Camera
Re: Chess Pieces
Postby Greolt » Tue Mar 28, 2023 10:51 pm
I downloaded a free stl model from one of the many sites specialising in 3D printer models.
Modified a couple of the pieces to make them more readily machinable on my 4th axis. Queen and rook.
The most challenging piece was the knight. It did not work so well with, what to me, is a normal 4th axis toolpath. X, A and Z
So I used the 4th axis as an indexer and machined from two sides.
https://www.youtube.com/watch?v=wmROvkcButc
Greolt
Re: Chess Pieces
Postby A_Camera » Wed Mar 29, 2023 11:15 am
Thank you. I watched your video and it is really nice work you have done. Did you add some weight at the bottom afterwards? The weight and balance is very important because otherwise the pieces fall over or move too easy. It improves the playing experience when players can concentrate on the game and not on keeping the pieces standing up on the right spot.
A_Camera
Re: Chess Pieces
Postby Greolt » Thu Mar 30, 2023 2:54 am
No weight added. The pieces all have a fairly large base. They don't feel like they are about to fall over.
I actually should have made the board squares a bit larger. Could feel just a little crowded.
However the kids won't even notice such a thing. :)
Greolt
Re: Chess Pieces
Postby A_Camera » Thu Apr 20, 2023 3:17 pm
Greolt wrote:No weight added. The pieces all have a fairly large base. They don't feel like they are about to fall over.
Thank you. Yes, maybe the board is a bit small, or the pieces are a bit too large... depending on how you see it. I asked because I have the King Performance Millennium Chess Computer and considering making steel pieces. Might be a bit too heavy, but I'll test with one and if I feel it's too heavy I'll make it out of aluminium. Anyway, it's a long term project because the design will take time. I only play with myself :lol: so it doesn't matter if the pieces are too heavy unless somebody knocks over the board and the pieces would fall on the living room floor. In that case, wooden pieces are better than any metal.
A_Camera
