Issue with THC
Issue with THC
Postby repauli1 » Wed Jul 14, 2021 2:03 am
When the software probes, it will sense metal and go to correct pierce height, but randomly and quite frequently the probe will sense material, and then raise about 2 inch and fire torch mid air.
On the UCCNC users group on Facebook this is happening to three different users.
I believe it may be false triggering do to noise?
It definitely is not the probing sensors causing the issues.
Any ideas?
repauli1
Re: Issue with THC
Postby Robertspark » Wed Jul 14, 2021 5:04 am
there is a software denounce setting
Re: Issue with THC
Postby cncdrive » Wed Jul 14, 2021 11:07 am
It's usually noise picked up by the probe wires.
As Rob wrote you can try the inputs debounce to filter the input signal.
Re: Issue with THC
Postby repauli1 » Wed Jul 14, 2021 11:50 pm
It appears the pc running uccnc is not sending all the code when this happens, is that even possible?
repauli1
Re: Issue with THC
Postby cncdrive » Thu Jul 15, 2021 6:19 am
What do you mean by that?
How did you determinate that the PC is not sending the code?
Re: Issue with THC
Postby repauli1 » Thu Jul 15, 2021 8:40 pm
Well it's not that, here is what I discovered though, there is a z command to raise to 2" before move to next pierce. It then should move to that point and probe for material height, the raise to pierce and fire torch. When it error out it fires torch before probing, see attached:
[ Play Quicktime file ] b5a42a60cbfc25bb26cae311fa5e8847.MOV [ 1.26 MiB | Viewed 7991 times ]
repauli1
Return to CNC Plasma
