ProbeIt for UCCNC
Re: ProbeIt for UCCNC
Postby Battwell » Fri Mar 06, 2020 2:04 am
I watched this today. Superb work !
Postby ThreeDJ16 » Fri Mar 06, 2020 5:04 am
Wow, very nice. Can't wait for you to release this.
ThreeDJ16
Postby eabrust » Mon Mar 09, 2020 2:42 am
Hi there guys,
I spent as much time as I could this weekend tying off as many of the loose ends of the ProbeIt plugin as I could, and working on a manual to go with the plugin. I'm ready to take a break from working on this a bit :) While I'll still call the plugin 'preliminary' and definitely incomplete, I think it is stable enough for others to try out and see how it works. As usual, I use inch units, so I hope there isn't anything that causes problem for you metric folks. If there is, let me know and I'll fix it up !
I've made the prelim version of the plugin available as a 'zip' file. It's to large to post here, so I've put it at the following linked page: http://www.craftycnc.com/probeit-for-uccnc/, with the download file here: http://www.craftycnc.com/download/598/. (fyi, The links here on the forum are the only pointers to the plugin currently).
Installation is easy:
ProbeIt_UC.dll goes into the plugins folder, and the ProbeIt folder should also get copied into plugins folder (with all its contents).
Please note, I've tried to make a reference manual (PDF) which can be accessed from a button on the 'About' tab, it also lives in the plugin\probeit folder to open it directly (and yes, the manual is a work in progress also...). I also left some sample output files in the folder as well to you can see if the DXF files it outputs are usable for you, etc.
Here is a short video on the 'surface probing' portion of the plugin. This is was incorporating a version of the 'ProbeCloud' plugin I've had available a while, and cleaning some stuff up with regards to file open/save issues. It isn't pretty, but it works. I'll save making it pretty for a new day.... and hopefully replace the 'charting' that I use for the display.
I look forward to your feedback, good and bad. Obviously, the bad feedback will do more to cause updates to the plugin than the good feed back :lol:
Postby markcadcam » Tue Mar 10, 2020 3:14 pm
I get this error using version 1.2113
markcadcam
Postby eabrust » Tue Mar 10, 2020 3:51 pm
markcadcam wrote:I get this error using version 1.2113
Hi Markcadcam,
Well thats a bummer... :oops:
Can you give some more info please? Did this happen as plugin loaded, or did it happen after you tried to run some routine?
thanks
Postby markcadcam » Tue Mar 10, 2020 3:59 pm
I enabled the plugin, restarted the program and I got that error on start up.
markcadcam
Postby eabrust » Tue Mar 10, 2020 4:53 pm
Thanks again, I will try to look at it tonight. I can't imagine there is anything between 1.2112 and 1.2113 that would matter.
Can you confirm you copied the 'probeit' folder and it's contents into the plugin directory? If you click continue, did it recover and run, or did it crash ?
And last favor I ask, could you please copy paste the text (scrolling down further to what is shown) from that exception window and either email it to me or paste here.
Postby markcadcam » Tue Mar 10, 2020 5:12 pm
Yes, I copied all of the files to the plugin folder.
Below is all of the error messages.
I'm running.
OS Name Microsoft Windows 10 Home
Version 10.0.18363 Build 18363
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentNullException: Array cannot be null.
at System.Reflection.RuntimeAssembly.nLoadImage(Byte[] rawAssembly, Byte[] rawSymbolStore, Evidence evidence, StackCrawlMark& stackMark, Boolean fIntrospection, Boolean fSkipIntegrityCheck, SecurityContextSource securityContextSource)
at System.Reflection.Assembly.Load(Byte[] rawAssembly)
at UCCNC.Form1.CurrentDomain_AssemblyResolve(Object sender, ResolveEventArgs args)
at System.AppDomain.OnAssemblyResolveEvent(RuntimeAssembly assembly, String assemblyFullName)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.4150.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
UCCNC
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/UCCNC/UCCNC.exe
System.Windows.Forms
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 4.8.4001.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 4.8.3752.0 built by: NET48REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
OpenTK
Assembly Version: 1.1.0.0
Win32 Version: 1.1.1664.6217
CodeBase: file:///C:/UCCNC/OpenTK.DLL
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
Win32 Version: 4.8.4121.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
銺翖됁꼰ꏺ趥蝠⌵
Assembly Version: 0.0.65535.65535
OpenTK.GLControl
CodeBase: file:///C:/UCCNC/OpenTK.GLControl.DLL
OpenTK.Compatibility
CodeBase: file:///C:/UCCNC/OpenTK.Compatibility.DLL
ILCalc
Assembly Version: 0.9.7.5
r0nl5dxz
Assembly Version: 0.0.0.0
AForge.Video.DirectShow
Assembly Version: 2.2.5.0
Win32 Version: 2.2.5.0
CodeBase: file:///C:/UCCNC/AForge.Video.DirectShow.DLL
Plugininterface
CodeBase: file:///C:/UCCNC/Plugininterface.DLL
AutoBackupProfile
Win32 Version: 1.1.0.0
CodeBase: file:///C:/UCCNC/Plugins/AutoBackupProfile.dll
AutoLevelerCA
CodeBase: file:///C:/UCCNC/Plugins/AutoLevelerCA.dll
C76 Fault Reporting
CodeBase: file:///C:/UCCNC/Plugins/C76%20Fault%20Reporting.dll
Console
CodeBase: file:///C:/UCCNC/Plugins/Console.dll
Debugger
CodeBase: file:///C:/UCCNC/Plugins/Debugger.dll
Diagnostics
CodeBase: file:///C:/UCCNC/Plugins/Diagnostics.dll
FaultSignals
Assembly Version: 1.2.0.0
Win32 Version: 1.2.0.0
CodeBase: file:///C:/UCCNC/Plugins/FaultSignals.dll
Laserengrave
CodeBase: file:///C:/UCCNC/Plugins/Laserengrave.dll
Lubricator
CodeBase: file:///C:/UCCNC/Plugins/Lubricator.dll
Modbusmaster
Assembly Version: 1.5.0.0
Win32 Version: 1.5.0.0
CodeBase: file:///C:/UCCNC/Plugins/Modbusmaster.dll
Pinout
Assembly Version: 2.7.1.0
Win32 Version: 2.7.1.0
CodeBase: file:///C:/UCCNC/Plugins/Pinout.dll
Plugintest
CodeBase: file:///C:/UCCNC/Plugins/Plugintest.dll
Printer3D
CodeBase: file:///C:/UCCNC/Plugins/Printer3D.dll
ProbeIt_UC
CodeBase: file:///C:/UCCNC/Plugins/ProbeIt_UC.dll
Probing
Assembly Version: 1.3.2.0
Win32 Version: 1.3.2.0
CodeBase: file:///C:/UCCNC/Plugins/Probing.dll
Profiler
CodeBase: file:///C:/UCCNC/Plugins/Profiler.dll
Scope
CodeBase: file:///C:/UCCNC/Plugins/Scope.dll
UCCAM
CodeBase: file:///C:/UCCNC/Plugins/UCCAM.dll
UCCNC_OSK
Assembly Version: 1.7.3.0
Win32 Version: 1.7.3.0
CodeBase: file:///C:/UCCNC/Plugins/UCCNC_OSK.dll
UCR200Plugin
CodeBase: file:///C:/UCCNC/Plugins/UCR200Plugin.dll
UCR201Plugin
CodeBase: file:///C:/UCCNC/Plugins/UCR201Plugin.dll
Webcamera
CodeBase: file:///C:/UCCNC/Plugins/Webcamera.dll
Xbox360controller
CodeBase: file:///C:/UCCNC/Plugins/Xbox360controller.dll
XHC-HB04_pendant
CodeBase: file:///C:/UCCNC/Plugins/XHC-HB04_pendant.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
markcadcam
Postby thegreatwaldo » Tue Mar 10, 2020 10:30 pm
Hi Eric
I'm getting the same kind of error as Markcadcam with ver. 2.113 and win7 I'll try it on my machine computer which probably has an older version to see if that works and get back to you.
Here's the error message win7 32bit uccnc 2.111
mscorlib
Win32 Version: 4.7.3416.0 built by: NET472REL1LAST_B
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
UCCNC
Win32 Version: 4.7.3324.0 built by: NET472REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 4.7.3221.0 built by: NET472REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
OpenTK
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
Win32 Version: 4.7.3429.0 built by: NET472REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
OpenTK.GLControl
ILCalc
zsyei5e1
Plugininterface
AutoBackupProfile
AutoLevelerCA
Console
Debugger
Diagnostics
FaultSignals
Laserengrave
Lubricator
Modbusmaster
Pinout
Assembly Version: 2.5.0.0
Win32 Version: 2.5.0.0
Plugintest
Printer3D
ProbeIt_UC
Probing
Profiler
Scope
UCCAM
UCCNC_OSK
UCR200Plugin
UCR201Plugin
Webcamera
Xbox360controller
XHC-HB04_pendant
enabled.
For example:
<configuration>
</configuration>
Cheers
Andrew
Last edited by thegreatwaldo on Tue Mar 10, 2020 10:47 pm, edited 1 time in total.
thegreatwaldo
Postby thegreatwaldo » Tue Mar 10, 2020 10:46 pm
Hi Eric
It's the the Probeituc.dll file that cause the problem stopping the program from starting properly.
Cheers
Andrew
thegreatwaldo
