1.2112 screenset
Re: 1.2112 screenset
Postby dezsoe » Tue Oct 08, 2019 5:05 am
The probe button on the main screen calls the M31.txt macro, so it's independent from the probe screen.
:) It was yesterday when I first thought of making apply and save buttons. I was also thinking about using the same apply and save as all the otuher settings.
Normally, you should have M5 in your g-code to stop the spindle.
Postby NikolayUA24 » Tue Oct 08, 2019 6:09 am
cncdrive wrote:Nikolay,
I'm trying to figure out what the issue is all day long, but see no problem at all in the code. :(
So, I've made a new exe file. Could you please make the screenset file as the original, I mean the slider and also the addfieldtext is back, so it will crash,
but I've put a number of MessageBoxes into this exe and would like to know what do you see on them and it is also interesting to see at which point will is crash.
Changed all the files to the original. And threw your file. The result in the photo.
I use Google Translator.
NikolayUA24
Postby cncdrive » Tue Oct 08, 2019 6:27 am
Thanks.
Then the issue is not where I was looking all day long. :(
I mean it runs through all 5 steps I've placed, so it finishes the slider value update without crashing.
I've made again a new exe, now I removed the redraw event of the slider image to see if it crashes there.
Could you please test this, I only want to see if it crashes or not. Attached the exe file.
UCCNC.zip
(1.64 MiB) Downloaded 457 times
Postby NikolayUA24 » Tue Oct 08, 2019 6:58 am
cncdrive wrote:Thanks.
All OK
NikolayUA24
Postby cncdrive » Tue Oct 08, 2019 7:01 am
OK, thanks. Then I know where the problem is, just have to figure out what it is exactly and how to fix it. :)
Postby cncdrive » Tue Oct 08, 2019 7:08 am
OK, please test this one too and let me know if it crashes?
UCCNC.zip
(1.57 MiB) Downloaded 475 times
Postby NikolayUA24 » Tue Oct 08, 2019 7:09 am
cncdrive wrote:OK, thanks. Then I know where the problem is, just have to figure out what it is exactly and how to fix it. :)
When I click on - or + the slider is in place, it does not move.
NikolayUA24
Postby cncdrive » Tue Oct 08, 2019 7:12 am
Yes, I know, it's not a problem that the slider is not moving now. I'm just testing a few things, with disabling some codes, that is why it is not moving, because the redraw was disabled.
Can you please test the last upload and let me know if that crashes or not?
I just want to see now when it crashes to see which exact code is causing it.
Postby NikolayUA24 » Tue Oct 08, 2019 7:15 am
cncdrive wrote:OK, please test this one too and let me know if it crashes?
Everything is working. OK ;)
NikolayUA24
Postby cncdrive » Tue Oct 08, 2019 7:17 am
OK, then I know that deleting the texture with OpenGL is the problem. I just have to figure out why and how to further debug this. This particular code is not easy. Will have to think about it a bit...
