Colorpicker boxes on apearance page
Postby Greolt » Sat Apr 12, 2025 1:40 am
With that earlier version of UCCNC that I started with, I edited the default screenset to suit my own preferences. Both for plasma and router.
As you may know it is quite a time consuming thing to do.
I am trying to bring that screenset up to date with later versions of UCCNC without doing all my own edits again.
So where I am having difficulty is mostly on the appearance page. There are more color selection boxes and some more checkboxes in later versions.
The color selection boxes are called Colorpickers in editing mode. There is no list in documentation for Colorpickers.
So how do I set a new Colorpicker box to a specific item?
Greolt
Re: Colorpicker boxes on apearance page
Postby ger21 » Sat Apr 12, 2025 12:19 pm
Open the default screen, and use the screen editor to find their numbers.
Postby Greolt » Sun Apr 13, 2025 6:07 am
Yes I was doing that. Expected something more than label number to assign to a Colorpicker.
Anyway I have now updated my screenset ready for 2118 when it is the stable release version.
Greolt
Postby Greolt » Mon Apr 14, 2025 2:02 am
The only thing I cannot get right is the "Default toolpath view" selector on the appearance page.
Pic is of 1.2118 and my screenset.
14-04-2025 11-57-06 AM.jpg (9.1 KiB) Viewed 3422 times
No big deal, not concerned by it.
Greolt
Postby ger21 » Tue Apr 15, 2025 11:49 pm
You have to edit the screen file to get comboboxes to work.
Go into your screen file, and find these similar lines, which is the box you added to the screen. Make sure it's label #12.
AS3.Addcombobox("Arial", 746, 400, 100, 16, -16777216, 0, 12, 9);
AS3.Clearcomboboxitems(12);
Then add these lines immediately following the above lines, and save the screen.
AS3.Addcomboboxitem("view45", 12);
AS3.Addcomboboxitem("viewright", 12);
AS3.Addcomboboxitem("viewleft", 12);
AS3.Addcomboboxitem("viewtop", 12);
AS3.Addcomboboxitem("viewISO", 12);
AS3.Addcomboboxitem("viewlathe", 12);
AS3.Validatenewcomboboxitems(12);
AS3.Updatecomboboxselection(0, 12);
It should then work.
Postby Greolt » Wed Apr 16, 2025 8:18 am
Wow Gerry, I never would have worked that one out in a month of Sundays.
Could not get my selection "ViewTop" to stick, so I edited this line to select option 3.
AS3.Updatecomboboxselection(3, 12);
Thanks again.
Greolt
Postby Greolt » Wed Apr 16, 2025 9:01 am
Correction:
It would not stick because I was running 1.2115
It does in 2.118
Greolt
Return to Custom Screensets
