Screen set 2022 tool change Problem
Postby woffler » Wed Dec 11, 2024 3:37 am
Hello everyone ,i have been running the screen set for years and today when i set the tool setter height and the mill moved to the fixed plate pos. it came down and probed the tool and came back up and then to takes off in the wrong direction blows past the fixed plate and runs into a limit.
When it should have moved to the G54 offset and run the program ,i have verified the steps are correct and it will move correctly from the MDI to a commanded position ,tool change position is correct and fixed plate location is correct .
I have tried changing the fixed plate position to a different number and it still does it ( i also hit go to change position and it does the same thing ) rus off in x - till it trips a limit switch .
I am guessing that maybe the M6 Macro has become corrupted some how i have not change a thing that i know of .
Thank You
woffler
Re: Screen set 2022 tool change Problem
Postby ger21 » Fri Dec 13, 2024 7:44 pm
Can you email me your profile?
Also, was this during a tool change, or when using the "Calibrate Tool Setter" button?
Return to Custom Screensets
