UCCNC - Segmag screenset
Postby jc.crespo » Tue May 02, 2023 5:03 pm
I spend a lot of time to adapt uccnc to my needs.
I just sharing this screenset here to help if someone need ideas.
But I will not share the screenset because I have many many macros associated to the butons and alot of the work is in portuguese.
Thanks for watching!
jc.crespo
Re: UCCNC - Segmag screenset
Postby cncdrive » Thu May 04, 2023 8:39 pm
What about offering the screenset for sales with licensing it to the serial number of the motion controller?
Postby jc.crespo » Sat May 06, 2023 10:58 am
yes, we can offer the screen for sale, no problem.
But we have to see the best way to do that.
I my case I have the custom pcbs (that i can offer for sale to), and the screenset mach all the inputs and outputs, or I have to do a different screenset without some functions
jc.crespo
Postby jc.crespo » Sat May 06, 2023 11:03 am
You can see a video of the automatic dust collectro working :)
https://photos.app.goo.gl/VgPd2KRLDoCEYUKX9
jc.crespo
Postby ger21 » Sat May 06, 2023 4:33 pm
Very cool!!
Postby XYZ_Spec » Mon May 08, 2023 10:09 pm
Oh man, that's so cool. It has a bit of lag while adjusting, or it's supposed to be like that?
BTW, the screenset looks amazing.
XYZ_Spec
Postby jc.crespo » Wed May 10, 2023 7:08 am
Hi XYZ_Spec, thanks!
yes, it has a little bit of lag because I have a macro reading the z axis coordinates and then I adjust the dust collector, you can see the lag in the video because the gcode is like a 3d work, if you are cutting parts, you can't see the lag.
jc.crespo
Postby ger21 » Wed May 10, 2023 10:51 am
Our Morbidelli adjusts the shoe based on material thickness and tool length. The material thickness is in the gcode. You can also specify an offset distance from the material to get it closer or farther from the material.
Postby jc.crespo » Wed May 10, 2023 11:15 am
I Gerry, thanks for the tip.
​At this moment our shoe is working with the length of the tool and you can add an offset to every tool.
But we have program the shoe to work with the z zero of G54-59 at the surface of the part to be machining, and then we have a second option that force the shoe to be always at the surface of the material ​
that you can see on the video.
Probably, the best way to program the shoe is like Morbidelli
jc.crespo
Postby Daywalker » Mon May 22, 2023 4:33 pm
Wow, the screenset looks really interesting.
Regards from Germany
Udo
(UC300ETH & UB1)
[Yeah, I use a Translator ;-) ]
Daywalker
Return to Custom Screensets
