by rfsx15 » Wed Apr 01, 2020 11:23 pm
Neon screenset observations:
1. Compared to 1.2112, I have to change both Y and Z axis dir_pin to active_low.
2. When I by accident bury an axis at its max/min, I am unable to bring it off the home/limit switch (it does work occasionally) once I clear the reset button.
I have only one home switch per axis, that doubles as a limit switch.
3. Under the Probe section (mid screen), everything works except...when performing a simple 'touch probe function', the movement of the Z axis is in the wrong direction.
If I change the Z axis dir_pin from active_low to active_ high, the Z axis probes in the correct direction, but now the 'ref. Z axis' (homing the Z axis) is in the wrong direction.
It appears that the Probe Z axis direction does not take into account the correct Z axis settings??
I really enjoy the layout. It is nice having the jog functions available on the screen. The probing function screen is better organized. The probing help file is a very nice feature. Love the large tool path display.
Thanx again!
