Is it possible?
Is it possible?
Postby laki » Thu Apr 11, 2019 7:21 pm
Hello
I am trying to make a new screen set so I have a question about probing the function. Software ver 2109.
I'd like to rearrange the existing probing tab and add a few layers to it. Also, I would set Probing Tab (layer 26) so that his parent tab is layer 1. Will the probing plugin work if I do this?
Probe Tab should look like this with additional layers.
Link to video
https://www.youtube.com/watch?v=4ly58VOYsEs
laki
Re: Is it possible?
Postby ger21 » Thu Apr 11, 2019 7:25 pm
It shouldn't matter what layers you use, as long as the button numbers are correct.
Re: Is it possible?
Postby laki » Thu Apr 11, 2019 7:29 pm
Thank you, Gerry
laki
Re: Is it possible?
Postby thegreatwaldo » Fri Apr 12, 2019 5:48 am
Hi Laki
Nice screenset.
cheers
Andrew
thegreatwaldo
Re: Is it possible?
Postby dezsoe » Fri Apr 12, 2019 6:51 am
Well, it should not matter, but it does. :)
If the Probe layer is selected then the probing plugin changes the active layer to that layer where the selected mode can be found. So, when you select the probe layer then that page will be displayed where the selected mode can be found. I have to think about how to turn it off or automate.
@laki, I send you a PM.
Re: Is it possible?
Postby laki » Fri Apr 12, 2019 7:55 am
Thanks Andrew
Dezsoe, I sent you mail to support at cncdrive dot com.
laki
Return to Custom Screensets
