Hi evryone,
the screenset is ready to release, if anyone is interested. Like a wrote before i sold the screenset (the whole project) to a friend of mine. He's a cnc machine builder (GP Proto CNC). He will sell the screenset on his web site:
https://www.gp-project.it/
Here are some feautures of the screen:
Support all UCCNC devices.
Works with the the last official release 1.2049 (tested with 1.2048 and 1.2049).
ATC feautures:
-linear toolchanger and presetting (simple to setup).
The options below need a probe (touch probe):
-manual tool change.
-broken tool change.
-change probe position.
-set workpiece zero.
-save tool height.
Plugin with the following feautures:
-handles the step distance DRO
This part is only if you use ATC.
-avoids to start the spindle if the ATC chuck is open (MDI and button check)
-avoids to open the ATC chuck when the spindle is on. (MDI and button check)
-avoids executing the Gcode if the ATC chuck is open.
-avoids to start the spindle from (HB04 pendant) when the ATC chuck is open.
Constructor macro (M99998) - loads settings from the profile (.pro file).
Destructor macro (M99999) - save settings to profile (.pro file).
Button (Load setting) needs if for some reason M99998 fails to load settings.
If someone needs help, don't hesitate to contact me (PM, email).
Thanks to all of you.
