help! screenset error during editing custom screenset
Postby Robertspark » Mon Dec 24, 2018 10:06 am
Help.... suggestions please.....
Basically I removed everything off the front screenset and have added new objects.
I didn't edit any combobox items so they should be fine and I think those are the only things with an "index"
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
   at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
   at UCCNC.GUI.Leavetextfieldswithoutvalidation()
   at UCCNC.GUI.gl_main_mousedown(Object sender, MouseEventArgs e)
   at System.Windows.Forms.Control.OnMouseDown(MouseEventArgs e)
   at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.UserControl.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.7.3260.0 built by: NET472REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
UCCNC
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/UCCNC1/UCCNC.exe
    Win32 Version: 4.7.3221.0 built by: NET472REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    Win32 Version: 4.7.3190.0 built by: NET472REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    Win32 Version: 4.7.3056.0 built by: NET472REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
OpenTK
    Assembly Version: 1.1.0.0
    Win32 Version: 1.1.1664.6217
    CodeBase: file:///C:/UCCNC1/OpenTK.DLL
System.Configuration
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
蕾ᴋ瑾勻Ꮷ烚▥
    Assembly Version: 0.0.65535.65535
OpenTK.GLControl
    CodeBase: file:///C:/UCCNC1/OpenTK.GLControl.DLL
OpenTK.Compatibility
    CodeBase: file:///C:/UCCNC1/OpenTK.Compatibility.DLL
ILCalc
    Assembly Version: 0.9.7.5
a4aczha4
    Assembly Version: 0.0.0.0
Plugininterface
    CodeBase: file:///C:/UCCNC1/Plugininterface.DLL
AutoLevelerCA
    CodeBase: file:///C:/UCCNC1/Plugins/AutoLevelerCA.dll
Console
    CodeBase: file:///C:/UCCNC1/Plugins/Console.dll
Debugger
    CodeBase: file:///C:/UCCNC1/Plugins/Debugger.dll
Diagnostics
    CodeBase: file:///C:/UCCNC1/Plugins/Diagnostics.dll
Laserengrave
    CodeBase: file:///C:/UCCNC1/Plugins/Laserengrave.dll
Lubricator
    CodeBase: file:///C:/UCCNC1/Plugins/Lubricator.dll
Modbusmaster
    CodeBase: file:///C:/UCCNC1/Plugins/Modbusmaster.dll
Neuron
    CodeBase: file:///C:/UCCNC1/Plugins/Neuron.dll
Pinout
    Assembly Version: 2.1.0.0
    Win32 Version: 2.1.0.0
    CodeBase: file:///C:/UCCNC1/Plugins/Pinout.dll
Plugintest
    CodeBase: file:///C:/UCCNC1/Plugins/Plugintest.dll
Printer3D
    CodeBase: file:///C:/UCCNC1/Plugins/Printer3D.dll
Profiler
    CodeBase: file:///C:/UCCNC1/Plugins/Profiler.dll
Scope
    CodeBase: file:///C:/UCCNC1/Plugins/Scope.dll
UCCAM
    CodeBase: file:///C:/UCCNC1/Plugins/UCCAM.dll
UCCNC_OSK
    Assembly Version: 1.7.3.0
    Win32 Version: 1.7.3.0
    CodeBase: file:///C:/UCCNC1/Plugins/UCCNC_OSK.dll
UCR200Plugin
    CodeBase: file:///C:/UCCNC1/Plugins/UCR200Plugin.dll
UCR201Plugin
    CodeBase: file:///C:/UCCNC1/Plugins/UCR201Plugin.dll
Webcamera
    CodeBase: file:///C:/UCCNC1/Plugins/Webcamera.dll
Xbox360controller
    CodeBase: file:///C:/UCCNC1/Plugins/Xbox360controller.dll
XHC-HB04_pendant
    CodeBase: file:///C:/UCCNC1/Plugins/XHC-HB04_pendant.dll
ZedGraph
    Assembly Version: 5.1.5.28844
    Win32 Version: 5.1.5.28844
    CodeBase: file:///C:/UCCNC1/ZedGraph.DLL
Accessibility
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Microsoft.CSharp
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.CSharp/v4.0_4.0.0.0__b03f5f7f11d50a3a/Microsoft.CSharp.dll
System.Dynamic
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Dynamic/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Dynamic.dll
Anonymously Hosted DynamicMethods Assembly
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
r3lsunyc
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Re: help! screenset error during editing custom screenset
Postby dezsoe » Mon Dec 24, 2018 1:15 pm
Check the layer numbers of your objects if the layer exists. I've got the same error when I mistyped a layer number to a higher value.
Return to Custom Screensets
