Page 3 of 3
Re: 1000x500mm high precision router build - NEED FORUM HELP
PostPosted: Wed Sep 25, 2019 1:33 pm
by NUDEcnc
Hi
the machine is up and running !!!
I have many hours of video showing build the final result. I hope to post BUILD blog ASAP.
For now, this is the "first run" video. Hope you will like it.
VIDEO
https://youtu.be/b28x_RwMkcU
At the moment I have a big problem. And I need HELP !!!
I can"t set up my VFD to work with UCCNC !!!
UCCNC with UB1
VFD is Sunfar E550. Manual for VFD: https://www.fasttobuy.com//download/2018-05-04/Sunfar_E550manual.pdf
I have rs456 to USB dongle.
Can someone please help me with this problem ??
I do have TeamViewer access to CNC machine so it should be easy diagnostics if my settings are any good.
Also, I would appreciate if forum users could go and verify my UCCNC settings.
Thank You for the support
PostPosted: Wed Sep 25, 2019 2:13 pm
by ger21
I would use analog speed control, rather than modbus with RS-485, as it's much simpler.
UB1 ----- VFD
RPM
AH1 >>>>> VS
AO1 >>>>> AI
AL1 >>>>> GND
Start/Stop
NO1 >>>>> X1
CM1 >>>>> CM
You'll need to set the appropriate VFD parameters, but I don't have time to look them all up right now.
PostPosted: Wed Sep 25, 2019 6:40 pm
by NUDEcnc
HI @ger21. Thank you for advise.
Yes, I did try analogue control with no luck.
I will try to go through VFD manual again. Thank you for your help.
EDIT:
Some progress:
I can adjust RPM by UCCNC.
I CAN't start spindle by UCCNC. But when I start Spindle from VFD panel and I press "Spindle CW(M3)" on UCCNC it will change spindle direction.
Any help.
Regards Arek
PostPosted: Wed Sep 25, 2019 10:50 pm
by ger21
What do you have set for F0.02?
And F1.08?
PostPosted: Thu Sep 26, 2019 8:46 am
by NUDEcnc
My settings:
F0.02 - 1000
F1.08 - 11 - FWD control
Regards Arek
PostPosted: Thu Sep 26, 2019 9:46 am
by NUDEcnc
Hi, I did check all the settings of the VFD.
My spindle is 4 pole 800Mhz 24000 water-cooled.
This is all the settings which are different from manual default.
0.00-1
0.02-1000
0.03-33.3
0.04-800.0
0.05-2.0
0.06-4.0
0.08-5.0
0.11-4.0
0.12-800
0.13-380
0.23-5.0
1.04-800
1.05-1
2.06-180
2.08-700
2.09-0
2.10-50
3.11-400
3.12-750
3.14-1216
3.24-0
5.12-20
5.13-300.0
5.14-20
5.15-300
Thank you for Your help.
Regards Arek
PostPosted: Thu Sep 26, 2019 1:59 pm
by NUDEcnc
Success !!!
Settings for F0.02-1001
ger21 wrote:I would use analog speed control, rather than modbus with RS-485, as it's much simpler.
UB1 ----- VFD
memberlist.php?mode=viewprofile&u=814
RPM
AH1 >>>>> VS
AO1 >>>>> AI
AL1 >>>>> GND
Start/Stop
NO1 >>>>> X1
CM1 >>>>> CM
Special regards for ger21
