Arduino modbus control panel project
Postby Battwell » Sat Aug 18, 2018 4:53 pm
Arduino modbus io panel
5v LEDs in each button
Fun project for the week ahead
Engraved and cut on the router for the mill conversion
Uc300eth on router and mill
Re: Arduino modbus control panel project
Postby kawarider » Sat Aug 18, 2018 9:30 pm
Tell us more please! Very nice!
kawarider
Postby A_Camera » Sun Aug 19, 2018 6:09 pm
Looks very nice.
A_Camera
Postby alex_s » Tue Aug 21, 2018 11:26 am
very nice can't wait to see more :)
alex_s
Postby Battwell » Wed Sep 19, 2018 5:41 pm
Work got in the way of this
But did a bit more to it today
https://youtu.be/6QUOmCKuJHQ
Postby Robertspark » Wed Sep 19, 2018 6:17 pm
Looks good
Bit late now but ... :roll: .... Did you consider wiring the switches up as a matrix keypad..... Less wires
I know I keep advertising it but visuino is so easy to use for this sort of thing including setting up modbus
Rob
UCCNC v1.2108 Macro Manual
Postby Battwell » Thu Sep 20, 2018 12:17 am
I’ve looked at visuino but I’ve already got the modbus sketch done and long term tested.
Each switch has to be wired even as a matrix and as I have 36 in / 32 out I have plenty of pins
Easier to do them separate ( to keep track of)
I used to design fruit machines so know how to matrix. But in this case I can’t see the need
Hopefully have it up and running tomorrow - but then have a bit of scripting to finish up on uccnc side.
Il be using the LEDs as see/confirm from uccnc, not just seen at arduino.
I think I’ve finally worked out how to run it all 2 wire now too :-)
Postby A_Camera » Thu Sep 20, 2018 12:57 pm
The advantage of matrix wiring is not the number of wires but it reqires less inputs. I see no other reason for matrix connections. Of course, even less inputs are needed if analogue inputs are used, but otherwise if there are enough inputs are available then wiring each button to a dedicated input is the best solution even firmware wise because it results in more optimised and efficient firmware.
A_Camera
Postby Battwell » Thu Sep 20, 2018 3:59 pm
I’m happy!
Worked first time :-)
https://youtu.be/MyeXwe-75gk
Postby Battwell » Fri Sep 21, 2018 4:30 pm
macroloop-done (needs a bit more work. analogues next)
controls uccnc and reports back :-)
https://youtu.be/1ZgtuUYOtaY
