Using UCCNC via USB to Ethernet Adapter
Posted:
Wed Jun 04, 2025 5:05 am
by jah12
I am using UCCNC to control an Axiom AR6 cnc router via an Ethernet connection from a laptop computer.
I need to replace the computer, but many new computers do not have an Ethernet port. Can I run UCCNC via a USB to Ethernet adapter.
Regards
John
Re: Using UCCNC via USB to Ethernet Adapter
Posted:
Wed Jun 04, 2025 11:30 am
by ger21
Almost all mini PC's have ethernet ports, and they are only $100-$150.
Posted:
Wed Jun 04, 2025 1:46 pm
by arturod
Yes, you can use a USB to Ethernet adapter, but use a good one. Stay away from the cheap ones.
Arturo Duncan
https://cnc4pc.com
Posted:
Wed Jun 04, 2025 9:46 pm
Use one which directly connects to the USB port of the computer and avoid the ones with USB cable, because those are much more sensitive to EMI noise.
Posted:
Sat Jun 07, 2025 2:17 am
by jah12
Thanks to all for the comments.
I wanted to know it was likely it would work before laying out cash for a new computer.
I was looking at a cheap Celeron based laptop as UCCNC is not too demanding as long as you are not running thousands of lines of code.
I have found that these cheaper laptops only have usb and hdmi ports.
Ethernet ports seem to have been deleted as most things become wifi connected.
Cheers
John
