Hi all,
I am about to receive a renishaw TP1s probe and am looking into incorporating a Renishaw MI8 interface unit to the system. Honestly, I don't really know how much the MI8 unit will improve the accuracy of the probe or its life span (from reduce arcing?), but for the price I have seen them, I could happily try it!
My question is the wiring oF the MI8 to an AXBB-e unit. The MI8 signal output is shown as "SSR voltage free" (which can be set as NO or NC) and I am not sure if that is compatible with the isolated inputs on the AXBB?
I am not much of an electrician, but does "voltage free" simply mean that the B6 and B7 outputs are basically the same as what is shown for a probe on page 28/29 of the AXBBe manual (v 1.0002)?
Ie. B6 and B7 are not going to be 24v+ and 24v-? I am thinking that if this is the case then wiring in the MI8 will be no different to what is shown in the axbbe manual or the tool height setter I have already been using (with awesome results, link below).
I also happen to have a Renishaw MP9 in transit that I stubbled across and couldn't resist. I am thinking that this unit will be much harder to use with the axbbe and UCCNC?
Any help would be much appreciated and I would be happy to post results or findings or the probe and MI8 interface unit if anyone would like to see them?
Cheers
https://www.renishaw.com/resourcecentre ... unit--7862
https://www.aliexpress.com/item/1005002 ... 1802DUJpAB
