UCCNC MODBUS MACROS.
Postby shakil1740 » Mon Jul 11, 2022 10:10 pm
// Check CW and CCW LEDs, start or stop the spindle based on LED states.
// After exiting this macro the Modbus register is set up for CW, CCW or Stop
if ( AS3.GetLED(50) == true ) // If the RUN CW LED is active
exec.SetModbusregister(SpindleRunReg, RunSpindleCW); //Turn spindle on in CW rotation if LED is on
else
if ( AS3.GetLED(51) == true ) // If the RUN CCW LED is active
exec.SetModbusregister(SpindleRunReg, RunSpindleCCW); //Turn spindle on in CCW rotation if LED is on
else // CW and CCW LEDs are off, send turn spindle OFF commnad
exec.SetModbusregister(SpindleRunReg, StopSpindleRun); // Send Rexroth EFC5610 STOP command to VFD
In this code snippet " if ( AS3.GetLED(51) == true ) // If the RUN CCW LED is active
blah blah
else
blah blah
not working but
" blah blah "
without if statement works perfectly fine.
please help. Thanks in advance.
shakil1740
Re: UCCNC MODBUS MACROS.
Postby shakil1740 » Sat Jul 16, 2022 1:15 am
OK finally found the solution,
This code worked flawlessly,
[attachment=0]M20220.txt[/attachment]
M20220.txt
(1.27 KiB) Downloaded 165 times
shakil1740
Postby shakil1740 » Sat Jul 23, 2022 3:05 am
YL620-A VFD revised codes for CW and CCW directions are as follows.
// M20220 MODBUS macro for YL620-A VFD
 while(exec.IsMoving()){}         // Do nothing until system come to Idle
                                              // This is the most important part of the macro
 bool CW_LED   = AS3.GetLED(50);                    // Check if CW led is ON or OFF
 bool CCW_LED = AS3.GetLED(51);                    // Check if CCW led is ON or OFF
 string Sset_DRO_Value = AS3.Getfield(869);             // Read Sset DRO
 double RPM = Convert.ToDouble(Sset_DRO_Value);   // string to double to uint.NO.
 ushort FREQUENCY = (ushort) (RPM / 6);                  // And convert RPM to FREQUEY
   exec.SetModbusregister(1, FREQUENCY);                // Send FREQUENCY VALUE to VFD
 ushort RunSpindleCW   =  18;                      // YL620-A RUN CW command
 ushort RunSpindleCCW  = 34;                      // YL620-A RUN CCW command
 ushort StopSpindleRun    = 1;                      // YL620-A STOP command
 if (CW_LED == true)                                            // If CW LED is ON
  exec.SetModbusregister(0, RunSpindleCW);        // Send RUN CW command to VFD
 else        // else if CW LED OFF
 if (CCW_LED == true)                                         // If CCW LED is ON
  exec.SetModbusregister(0, RunSpindleCCW);     // Send RUN CCW command to VFD
  exec.SetModbusregister(0, StopSpindleRun);     // Send STOP command to VFD
// End of File
M20220.txt
(1.66 KiB) Downloaded 142 times
shakil1740
