Output stops, during several actions
Postby trendsetter » Fri Sep 18, 2020 6:11 pm
Dear all,
I have a vacuum pump for tool on one of my outputs controlled by a macro, which is switching a shunt for driving the pump.
The vacuum is for tool holding purpase. Once I load new G-code (explorer window) as well as M6 command the Outbup is switched off.
What can be the issue for that?
BR
Michael
trendsetter
Re: Output stops, during several actions
Postby dezsoe » Fri Sep 18, 2020 7:28 pm
Give much more information: program version, controller, how do you switch and which output, etc. Also, upload your profile, because there can be a setting which interferes with your macro.
Postby trendsetter » Fri Sep 18, 2020 10:44 pm
Hi, I solved it. I had some overlap with the cooling functions. Therefore it was switched off.
BR
Michael
trendsetter
Postby dezsoe » Sat Sep 19, 2020 6:48 am
That was what I thought. Pin mapping plugin helps you finding these problems.
