This is a fresh install, UC400ETH, C11G, I imported this configuration from mach3 and have been having difficulty getting Z moving the right direction. Currently, I would set the Z Dir Pin to Active Low to get Z to move up with pg-up and down with pg-down, but no matter how that Active Low switch is flipped, the axis jogs the wrong way, and the DRO reads the wrong direction. Changing the homing direction does change the direction of the homing, but not the axis direction (as expected) I've tried a number of things but just can't get this to work.
This is only the Z that shows this behavior, not the other 3 axis I'm using.
Additionally, I can't disable the B and C axis and when I try to do things like auto calibrate the soft limits on X the Y starts moving. Flipping check boxes doesn't save when pressing the save button, etc. There is all kinds of stuff happening that I can't figure out how to resolve. This is on version 1.2111
