by Robertspark » Fri Sep 13, 2019 2:45 pm
dhanger ... pee on the electric fence and give it a go.
report back if you find anything that doesn't work like you want it to and we can see if there is a way around it.
Do you need the brake engaged when the RESET / ESTOP is active ? The problem with that one is you probably want the spindle to decelerate first before applying the brake.... it can be done via macroloop watching the spindle speed. its not difficult or complicated, but start somewhere and see where it gets you.
I've had a little think when time permits and I cannot figure out the "great mystery" mentioned earlier as to why what was proposed may not do what you want it to do.
Obviously dry run it and simulate whatever scenarios you can think of (estop / reset, feedhold, run, stop, mdi, gcode etc etc).
Let me know if you need any other help and I'll try to help out and maybe someone will chip in with something useful and clear.
Good luck
