Screen Editor
Screen Editor
Postby Vmax549 » Sun Aug 11, 2019 11:02 am
HUMMM, I simply added a new page. Easy enough it seemed. I have done it many times before. BUT I saved it out and then restarted UCCNC and this is what comes up now. IF you click on a tab it all goes back to normal and everything works fine. It is just on startup teh screenset is a mess. Any EASY way to fix this ??
(;-( TP
Vmax549
Re: Screen Editor
Postby cncdrive » Sun Aug 11, 2019 2:46 pm
My bet is that both layers are selected and so both are visible is how the sceen was saved.
The software always saves the actual layers selections into the screenset file when you save the screenset.
An easy fix is to click the layer (You wrote that then it becomes to appear fine) and then save it with the screen editor.
Re: Screen Editor
Postby Robertspark » Sun Aug 11, 2019 5:00 pm
two layers have the same number
Re: Screen Editor
Postby Vmax549 » Mon Aug 12, 2019 12:21 am
I found the problem. The screen editor had deleted the reference to layer 2 from the startup list.
(;-) TP
Vmax549
Re: Screen Editor
Postby Vmax549 » Mon Aug 12, 2019 12:53 pm
Well each time I go back and modify teh screen it blows up when It is saved so I do not know how to fix it. I have to go into teh actual screen file and fix it manually. And I still have 1 page I cannot fix.
I guess it is what it is, (;-) TP
Vmax549
