Good to know
Thanks Balazs
beefy wrote:Delay starts from when the Arc OK signal is received .
The option should NOT be set for Plasma Cutting WITH the THC active because then you get dueling inputs AND it will move the Z the first UP or DOWN signal it gets and overrides the THC Delay. it creates problems during and right after the pierce where the torch will bounce wildly if you do not have the delay built in.
beefy wrote:Regarding what you said:
In almost every plasma setup instructions I ever saw, the recommendation was to have this checked in Mach3
I was surprised to hear that as I've never came across any recommendations to do that when plasma cutting and I started with Mach3. I've never had it checked for plasma work.
Users browsing this forum: Bing [Bot] and 7 guests
