Hi and thank you for your help.
I am using proximity sensors on my machine. It has an indicator light. Picture below.
I am also using Gerry's 2017 screen set.
When the machine homes, it stops where it activates the sensor but does not move back to "clear" the sensor. In other words, even though the screen shows the axis has homed, the "on" light on the sensor stays on because the machine does not back off of the sensor and that prohibits the other axis to home.
What am I doing wrong? Is there a setting where I can adjust the back-off amount?
Thank you,
David
