Settings not saving
Settings not saving
Postby DWhiteR1 » Sun Oct 28, 2018 8:25 am
When I try set the Step and Dir ports and pins they go back to zero when I press save.
Please help
Regards,
Dean.
DWhiteR1
Re: Settings not saving
Postby cncdrive » Sun Oct 28, 2018 8:31 am
It is because the setting you made is wrong. You trying to attach an input port pin to an output function or an output port pin to an input function.
Postby DWhiteR1 » Sun Oct 28, 2018 8:50 am
I'm trying to assign pin 2 to step and pin 3 to Dir
Im using a HDBB2 board, on page 5 of the documentation for HDBB2 it says X axis step signal pin = 2 and dir = 3
The HDBB2 board is plugged into port 1 of my UC300ETH.
So I set the port to 1 and the pins to 2 and 3 respectively.
What am I missing? :-(
Regards,
Dean.
DWhiteR1
Postby DWhiteR1 » Sun Oct 28, 2018 9:01 am
OK, Got it,
I saw on diagnostics screen and changet to port 2
Its working now.
sorry, my first time using UC300 and UCCNC
Thank you.
Regards,
Dean
DWhiteR1
Postby cncdrive » Sun Oct 28, 2018 9:31 am
No problem.
On port#1 pins 2. to 9. are inputs and not outputs, but I see you already figured it out. :)
