machine coordinate's
Postby Dan911 » Wed Oct 10, 2018 2:33 am
I'm trying to capture machine coordinate's on the start of current gcode line before movement or the end 0f previous. I monitored the obvious available fields/functions but always slightly units ahead, a routine with DTG fields come close but still not 100% reliably accurate. Any Suggestions?
Re: machine coordinate's
Postby Robertspark » Wed Oct 10, 2018 6:39 am
double WorkCoordA = exec.Wa;
double WorkCoordB = exec.Wb;
double WorkCoordC = exec.Wc;
double WorkCoordX = exec.Wx;
double WorkCoordY = exec.Wy;
double WorkCoordZ = exec.Wz;
Rob
UCCNC v1.2108 Macro Manual
Postby Robertspark » Wed Oct 10, 2018 6:49 am
Oh, are you doing this on the fly?
if the machine is moving then you would need to use stream reader to read the current or next gcode line, and also the current work coordinates,
subtract the current work from machine coordinates to give you the current offset, and the subtract that from the gcode coordinates
dont forget uccnc buffers data and shifts it to the motion controller so that the motion controller will do all the timing, and the buffer allows for any windows delays,
windows is not real time, and does not have a real time kernel. Linuxcnc does .... but technically there is still a delay.... just its very small (subject to pc, network connection, processor etc)
in uccnc you only read the data as available which will always be off a bit. I think there is a buffer delay variable somewhere which is used for diagnostics in uccnc that yoy may be able to use to estimate a closer actual prediction using a predictive filter like kalman
Rob
Postby Dan911 » Wed Oct 10, 2018 8:57 pm
Hi Robert.
The exec.Wa; etc... functions don't seem to be available in plugins, but your reply did put things in perspective for me.
Thank you,
Postby Robertspark » Wed Oct 10, 2018 8:58 pm
They should be available try uc.Wa etc
Rob
Postby Dan911 » Wed Oct 10, 2018 9:14 pm
Yes of course....UC.Wa
Also UC.ArcstartposX, they don't show up in my list of functions. Were they added after 1.2105?
Postby Robertspark » Wed Oct 10, 2018 9:20 pm
Err.... There are a few undocumented ones ....
I've been holding out a bit as they are not official... I'll add some to the new (macro) manual in a specific section.... Just substitute exec for UC and they should work fine
Rob
